Old 06-06-2004, 03:30 AM
something_funny something_funny is offline
Send a message via MSN to something_funny
audio system cuts out when turned up
Hey all just after a bit of help.
I have a 1985 Mazda 626, i know old, and crappy, but i am a student, and i have to do with it for now. I have for a while had installed a cd head unit, a set of 6.5" speakes in the front, as well as a set of 6.5s in the back, also have a 700 watt amp powering 2 12" subs. now the problem is when i turn the deck up to a certain point, it restarts, i figure this could be due to not enough power, but am after a few opinions. Could capacitor help stop this? any suggestions i would be greatful for. O and what can i say about having a good sound system in my crappy car, other than i like my music.
Old 06-06-2004, 02:37 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: audio system cuts out when turned up
amp could be overheating, headunit could be overheating, lots of possibilities
Does everything cut out? Just the subs? When you say it restarts, are you saying it starts back at the beginning of the song or it just cuts out and then comes back?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 06-06-2004, 11:11 PM
when i say that it cuts out i mean the whole audio system (head unit, amp, whole lot. when i say it restarts i mean that the head unit turns off and then back on. It only does this when i turn it up past a certain point. however come to think of it, it also cuts out when the cooling fan kicks in (that is when the head unit is turned up to a certain point). As i say i think that maybe i am draining to much power. But i am very thankful for any input. I am after a cheap, or even just suggestions as to what i can do to fix this problem. Thankyou
Old 06-07-2004, 06:52 AM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
I would check both your battery and your alternator; Im not really sure, but I want to say that the 626 has quite a small battery, and I'm sure that the alternator probably can't handle running the headunit and the amp especially. You may want to look into getting a higher-amp alternator first off, and then maybe a more powerful battery (If you even have a place for one under the hood)
Old 06-08-2004, 09:36 PM
Ok, thenks for that. That what pretty much well what i had in mind, but didnt wana go spend heaps of money to have the same problem. i am sure that if i dont have enough room for a bigger battery then meybe with a hacksaw u could make some. lol
