Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 06-06-2004, 01:29 AM
p_a_p_i p_a_p_i is offline
Reason for no start
If a supercharged car has fuel and fire; what would be the reason for it not starting? The injectors have fire to shoot fuel. Can a supercharger keep a car from starting? What can it be?
Old 06-06-2004, 12:34 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: Reason for no start
An engine needs three things to run. Proper fuel, Proper spark, Proper air. Many variables because of computer controlled systems. What events led up to a no start issue?
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 06-11-2004, 02:36 AM
The ORIG. Dig. Oxy's Avatar
The ORIG. Dig. Oxy The ORIG. Dig. Oxy is offline
Pull the codes (If any). ALWAYS hook up a code scanner and see what codes the computer spits out first.
Now, with that said, on one of our beloved Supercoupes, even the wrong pressure in the tires will prevent it from starting. I got your attention, eh? good.
I was kidding about the air in the tires, orfcourse. But here are some common problems on the SC's:
1. Crankshaft position sensor. -Does the Upshift light stay on when you are cranking the engine? (the Upshift light is a yellow light with an UP arrow on it). If it stays on during cranking, you have some nasty problems in the way of CrankShaft position sensor, and most likely Harmonic ballancer.
2. CPS - Camshaft position sensor, aka PIP. That's where the distributor would be on non SC 3.8 liter cars.
3. The supercharger will not prevent the car from starting unless it sucked in something big enough to plug it. Which is impossible. You may have some vacuum leaks, but that wouldnt prevent the car from starting. Just running.
3. Fuel pump.
Your best bet is to pull the computer codes. If it's something electrical like I have described above, the computer will throw a code. (except #3)
There are so many things that can prevent an SC from starting, that it would take me a long... LONG time to go through them all.
