Old 06-06-2004, 01:14 AM
steyr911 steyr911 is offline
Send a message via AIM to steyr911
Unhappy '94 EGR problems
I have a '94 Grand AM GT 3.1L engine. when i drive it at highway speeds, or if i redline it, a service engine soon light shows up. I got the diagnostic testing done, and the mechanic said the EGR vavle was bad, but he also said that since the EGR is non-essential, it was pointless to replace it for the 300+ dollars it would cost. the engine light is really annoying, so one day i took the valve apart, and i found a gray sludge stuck in the ports to the egr, and in the hose leading to the intake manifold, but none in the hose leading from teh exhaust manifold. i cleaned it out, and while it seemed like it helped i still got the light every now and then, so i took it apart again, and the sludge had returned! where can this sludge be from? i dont want to buy another egr valve if the engine is just gonna clog it up agian. can anyone help me out here?
thanks!
Dom
Old 07-05-2005, 06:27 PM
davyrocket1967 davyrocket1967 is offline
Try cleaning out the throttle body really good, make sure all the carbon build up is out. Hope that helps
Old 07-05-2005, 07:01 PM
Knifeblade Knifeblade is offline
Re: '94 EGR problems
Well, sort of like Davy is stating, the throttle body clean is a worthy try. The EGR vents exhaust gas through the exhaust manifold back into the valve cover, where the gases find their way back into the air-fuel mix to get re-burned. That is a very simplistic view of how it gets done. One major reason for your sludge is A] too rich a mixture or B] the valve or the ported vacuum feed to it is getting plugged and allowing the sludge to build up.
Old 07-05-2005, 07:03 PM
http://www.autozone.com/servlet/UiBr...3d800e5537.jsp
