Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 06-05-2004, 10:59 PM
sc3148 sc3148 is offline
2000 Chevy Venture Turn Signal Flasher Help
I'm having trouble locating the turn signal flasher on a 2000 Chevy Venture. Quit all together no clicking or signals, fuse is good. Any help would be greatly appreciated.
Old 06-20-2004, 02:55 PM
Re: 2000 Chevy Venture Turn Signal Flasher Help
Found It!
Old 08-20-2004, 06:56 PM
vmax442 vmax442 is offline
Re: Re: 2000 Chevy Venture Turn Signal Flasher Help
Found It!
I have a question for you. Was the flasher controller a black rectangular box with three or four wires coming out of it? If so, I have located the flasher as well, but my question is how do you unhook it or detach it from the wire harness?
When I use my turn signals the front and back bulbs do not blink, but the side ones do. Plus it blinks very fast. Any input would be greatly appreciated.
Thanks!!! vmax442
Old 08-21-2004, 11:20 AM
Re: Re: Re: 2000 Chevy Venture Turn Signal Flasher Help
Thanks!!! vmax442
Yes it's a black rectangular relay located under the hood just above and behind the brake booster. It is secured to the connector with a plastic clip, which has to be released with a long screwdriver or similar tool while pulling on the relay. You almost need three hands but there is very little room. If GM would have spent another 2 cents on wire they could have made it a lot more accessible. Good Luck!
Old 09-14-2004, 09:22 AM
jfk6008 jfk6008 is offline
Re: Re: Re: Re: 2000 Chevy Venture Turn Signal Flasher Help
Purchased the new flasher for my 2000 venture from the Chevy dealer.....parts guy printed a picture as to location of the flasher...under the dash directly to the left of steering columm.......the flasher was not there....then I saw your message above and spent an hour looking for the flasher at the location you described with no luck.........ANY other suggestions where to find the flasher???? Have an service appointement on Sat 9/18 that Id like to aviod. Thanks
Old 09-14-2004, 07:14 PM
I had the exact same problem with a print out from Chevy! If you look under the hood in line with the steering column just to the upper drivers side of the brake booster at the far back where the back wall meets the upper panel, it's either hanging from the wire loom or cliped to it. It is black and rectangular about 1.25 inch x 2 inch relay with 3 wires and a real bear to get to. In my search with the GM picture I had the complete left side the dash and center section apart before looking under the hood!
Old 09-16-2004, 12:31 PM
Frustration continues.......looked as you directed for an hour last night and still not finding it. I see two wire harnesses above the brake booster. Both terminate and not at the flasher. Any more suggestions. Thanks.
