Old 06-05-2004, 10:18 PM
Magik Si's Avatar
Magik Si Magik Si is offline
Weird vibration ?
My girlfriends 90 4-door auto. does this really odd vibration thing (farely loud too) when stopped but still in gear (ie. sitting at a drive through window). If she pushes it up into neutral the car stops vibrations...what's going on here? Any input?Thanks, Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Old 06-05-2004, 11:19 PM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
so its just rough idle
i dont know what you could do about it but i know the same thing happens to my dads corolla
88 civic dx
Old 06-05-2004, 11:23 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
its your idle. Its probably set too low. To see, when she has it in gear and yoru sitting there, give it the slighest bit of gas, if the vibration stops, then you know you gotta get your idle set higher. The same exact thing is wrong wiht my camry, too low of idle.
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 06-05-2004, 11:27 PM
Magik Si's Avatar
Re: Weird vibration ?
Very kewl...will definately try that! How to I adjust the idle (idle adjust screw?)
Thanks
Jason
Go Flames Go (4:00 minutes 1st overtime Game 6)
Old 06-05-2004, 11:56 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
think you answered that question on your own.
Old 06-06-2004, 12:01 AM
BullShifter's Avatar
Re: Re: Weird vibration ?
Thanks
Jason
First thing I would check for is loose exhaust heatshields, manifold,, a-pipe, cat, etc.
Everything you need is in the manual - http://www.binghamtonlife.com/manual...s/91-11-90.jpg or http://www.binghamtonlife.com/manual...s/91-11-91.jpg
Full manual for loads of information - http://www.binghamtonlife.com/manual/2gsm/default.htm
