Old 06-05-2004, 09:55 PM
fireman_103 fireman_103 is offline
changing opti
I am trying to change my opti,,,, I know the first step is to remove the water pump,,,I removed the four bolts to the water pump and cant get it to come off. I read where you have to remove the crank pully is that true,,,,Does anyone know where i can find a diagram for this.
Old 06-05-2004, 10:31 PM
tom3 tom3 is offline
Re: changing opti
Water pump has a couple locating lugs on it, aluminum and steel joint gets corroded, real tough to break loose. Six bolts?
Good web site:
http://www.fierolt1.com/lt1_95_up_OptiReplace.htm
Old 06-05-2004, 10:40 PM
Re: changing opti
oh mine is a 1997 > I only saw four bolts on mine
Old 06-06-2004, 12:47 AM
96CamaroSS's Avatar
96CamaroSS 96CamaroSS is offline
Re: Re: changing opti
Therer are six bolts holding the water pump on... You will probably have to remove the A.I.R pump and it's bracket to get the pump off. Don't lose the gear drive coupler that goes between the water pump and block. You might have to take off the crank pulley, but I'm not sure. I had the dealership do the optispark on my car.
Old 06-06-2004, 12:51 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: changing opti
Yeah the Air Pump and bracket must come off to get the waterpump off and all waterpumps on LT1 have 6 bolts its just hard to locate the remaining 2 feel around in there with your fingers and you'll find it
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 06-06-2004, 12:54 AM
FormulaLT1's Avatar
Fight the powwa!!!
Re: changing opti
Also you will need to remove the crank pulley to get the opti out not the waterpump
Old 06-06-2004, 10:20 AM
Deadcarny Deadcarny is offline
Re: changing opti
crank pully and water pump need to come off. 6 bolts on the water pump. since the opti is bad, inspect the waterpump for leakage around the weap hole as well.
1995 Camaro Z28, 383ci 485+hp 495ft-lbs SOLD!!!
1965 Ford F100
1967 Chevrolet Impala (Sold)
1972 Chevrolet Chevelle (Sold)
1972 BMW R60/5 (Sold)
1980 Harley Davidson FLH
1987 Harley Davidson XLH
1992 Astro EXT AWD
1992 Chevrolet Cavalier
2000 Monte Carlo SS Pace Car 1087/3222 (Sold)
2001 Pontiac Sunfire
2002 Trailblazer LTZ (Sold)
South Carolina F and Y Bodies
www.SCFYB.com
Old 06-06-2004, 03:34 PM
water pump
Thanks for all the input I think I have all off but the air pump bracket, Darn rain if comming down, Should have used the garage...........
Old 06-06-2004, 08:37 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Re: changing opti
www.delteq.com you'll never have to replace that thing again, hell you won't even have to replace it now. I guess usualy it's the cap and rotor that go on that thing. Check it out, I've heard some good things about it.
Old 06-07-2004, 08:24 AM
Re: changing opti
I have got it off, the damn thing looks ok to me, I went ahead and replaced the cap and the rotor, Cleaned the photo sensor and put it back together, I will be putting it back on tomorrow, I hope that is my stalling problem.
