Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 06-05-2004, 07:26 PM
86Bird 86Bird is offline
Not idleing back down:(
Ok the problem I'm having is that sometimes after I let off the gas my car wont go back to idle. I think the idle kicker solenoid might be the problem but I'm not sure. The solenoid plunger will follow the throttle arm out fine its just when you let off the gas the plunger seems to hold the throttle arm from going back in. Any ideas or suggestions? Because this is driving me crazy
~edit~ Its an 86 3.8
Old 06-06-2004, 12:41 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: Not idleing back down:(
Can you push it back in place by hand? With or without great difficulty? May just be time to replace it.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 06-06-2004, 06:56 PM
Re: Re: Not idleing back down:(
Yeah it pushes back in not too hard but I didnt know if there whould be something else wrong and thats why its not going back in the way it should be.
Old 08-06-2004, 07:31 PM
melfan melfan is offline
I had this problem as well. Your pic is of the AC saddle bracket with curb idel assembly. This only keeps the car from stalling when the AC kicks on. It could be over adjusted but will not do much for you.
I would check your Throttle position sensor. The TPS is located on the righ side of the Throttle body, directly connected to the throttle shaft.
I replaced mine and it seems to fix the problem but it still seems to idel down slow. Might just be the nature of the primitive TB's.
Old 08-12-2004, 05:14 PM
I dont have ac Or does it matter?
Old 08-12-2004, 07:36 PM
It must have at one time or it would not have the curb idle.
Old 08-15-2004, 11:16 AM
It didnt. I've had it for 5 years and the original owner was my grandparents.
Old 08-15-2004, 11:44 AM
Re: Re: Re: Not idleing back down:(
Is it hard enough that the throttle return spring can't push it in?
Old 09-16-2004, 06:54 PM
Re: Re: Re: Re: Not idleing back down:(
Nope. And it only does it sometimes.....but recently its been doing it more.
When it does it if you tap the gas peddle it will generally idle back to where its supposed too.
