Old 06-05-2004, 06:52 PM
1fastgtp 1fastgtp is offline
DIC Not Turning On???
Ive got a 2000 gtp and sometimes when I start the car, the DIC, the HVAC and the headlights wont turn on (the ambers and the fogs come on). After a few minutes everything just turns on. When this happens I can still turn on the headlights manually. Im not sure what is going on but I suspect a relay somewhere. And all the fuses are fine(obviously if everything turns on after a couple minutes).
Anyone have any suggestions???? This problem is really annoying.
Thanks.
Old 06-05-2004, 07:04 PM
michelq michelq is offline
Re: DIC Not Turning On???
most of the time is the ign switch but you have to check it when is acting up
Old 06-06-2004, 10:49 AM
BIG-L's Avatar
BIG-L BIG-L is offline
It could be the Ignition switch harness and the contacts are going bad.Here is a fix for it.....~Larry~
GM part number 26068757
Ignition switch harness." It is a thick cluster of heavy and lesser wires, about 1.5 feet long,
with robust termination blocks on each end. One end also has geared,
mechanical components. This part installs under the dash on the drivers
side and up into the steering column.
You need to replace it when your A/C fan begins to operate intermittently.
For example, if you are driving and the fan simply stops, then restarts
while on any speed setting 1-4 (not on speed setting five setting until some
weeks later ,) your switch is failing. The problem will gradually become
worse, with the outage taking longer to recover, until you achieve total
failure.
There are actualy two parts that can cause this problem, and the second part
is called the resistor pack. That part connects directly to the blower
housing under the dash on the passenger side, and is about 24 bucks new from
GM. My fully functional pack was slightly burned on the circuit board, so I
replaced it.
The fan ignition switch was easy to replace, but it is awkward to install.
You will need typical small hand tools, plus an 8-inch or longer socket
extension. a torx male socket (T11, I think) and two torx female sockets
(T11 and T10.) I didn't know that until I had my steering column torn down,
and had to drive around the city with a skeletal column, wires dangling and
tools in the floorboard. No one sells female torx wrenches that small, so
you will have to buy two small standard wrenches. (Your 1/8th inch drive
sockets are way too big to fit the space you will have to work with.)
Sears has a perfect solution. Buy the 5/32nd and 1/8th size wrenches on the
2.5 inch steel stems. They look like small screwdrivers with the socket
permanently mounted at the end of a thin, steel stem. You will need the
small stem because you won't be able to remove the cowl above the steering
column, and its in the way.
The physical key slot on the primary ingnition switch is too big for the
upper steering column cowl to slide over, so you will have to raise the
plastic cowl as far as possible to access the two very, very small torx
screws holding the fan switch in place. The cowl will be stressed, so be
careful.
Also, you will have to cut and splice two wires due to being unable to
remove the upper steering column cowl. There is some magic part snapped
into a slot on the top of the column that you will not be able to reach,
which will have to be left there. Cut the two wires coming off it and
splice them to the two matching wires coming off your new part. There is a
small, odd shaped white plastic box attached to one end the two wires.
Nothing comes out of the little box, and there are no metal contacts on the
surface of it. Apparently, there is something inside the box that sends
some kind of signal/magnetism/charge through its housing to a receiver in
the steering column. Or not. Who knows?
The wires are very plainly marked, they match the new ones and there are
only two. You can't screw it up unless you fail to insulate your splices.
If you don't insulate them well, then you can expect some really fun
problems later.
That job takes about 1.5 hours, and the part is 54 bucks from www.gmpartsdirect.com. GM
wants 98 dollars for it, and a shop will charge you around 300 dollars to do the job.
ClubGP Member 6530
Since 2001
Old 06-06-2004, 04:26 PM
Thanks for help. I'll try that this week when I get a chance.
