Old 06-05-2004, 04:09 PM
Ian10 Ian10 is offline
Cool Headlight breaker
My 89 siilverado has a 30 amp breaker
that runs the headlights and some dashlights
as well. The breaker runs very warm ( hot to the
touch) I get about a 10 amp reading on an amp meter.
The breaker only gets hot when the headlights are on.
Is this normal??
Thanks
Ian
Old 06-05-2004, 06:45 PM
michelq michelq is offline
Re: Headlight breaker
the only c.b on fuse box is for power window and power seat you not suppose to have c.b to light pull the c. b and put 20 amp fuse other wise you going to burn your wiring if the wire went to ground
Old 06-05-2004, 10:54 PM
desertmike1 desertmike1 is offline
I come up with low beams @ 45w x 2 / 14v = 6.42amps
your high beams @ 65w x 2 / 14v = 9.28amps
add dash and tail lamps and you could easily draw 10+ amps on low beam, and even more on high's
30amp protection seems a little high, check your book values.
-Mike
Old 06-06-2004, 08:09 AM
Thanks for the input
I bought it used and no book came with it.
I'm going to try to find one this week
