Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 06-05-2004, 03:11 PM
krogersl krogersl is offline
Unhappy LS Keypad entry.
I just purchased a used 2003 LS and do not have the code to use the outside keypad to unlock the car. Does anyone have any ideas? I checked all of the obvious areas for stickers and found none. I appreciate any help with this.
Thanks!
Old 06-07-2004, 02:11 PM
Quik_LS's Avatar
Quik_LS Quik_LS is offline
Send a message via MSN to Quik_LS
dealer only - in fact all the locking items - keypad, remotes,... can only be programmed by the dealer - unlike most other Fords where you can turn the ignition off and on a bunch of times to set it to program.
Quik LS - Austin, TX
more, more, more.....
#0018 ESP SCCA solo2
LLSOC.com - President
see my mean LS
see my Lotus Esprit - Quiker
Old 06-07-2004, 08:55 PM
Thanks, I appreciate the help on this very much!
Old 06-08-2004, 02:08 PM
joseg31039 joseg31039 is offline
Re: LS Keypad entry.
On my 94 continental there is a sticker on the right side trunk hinge that has the factory default it is the mater and will always work. Maybe your LS is the same.
