Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-05-2004, 10:47 AM
grovebaby grovebaby is offline
Unhappy 87 Caprice brake light problem
This is driving me to drink. rear brake lights don't function. Window light is ok. Tried numerous things. Switch is ok, I get power to the trunk at all times. changed out two sockets. Changed the ground lug, all bulbs. tried jumpering ground and power right to sockets (bypassing connectors and connectios) no good. I have gotten them to work for a few days at times. I'm starting to suspect something in the directional circuit since they use the same filament and power pins. Any help would be greatly appreciated. Also are there any sources on the net with schematics. I haven't found any. Thanks
Old 06-08-2004, 12:39 PM
okaynow , don't respond all at once
Old 06-08-2004, 07:29 PM
CD Smalley CD Smalley is offline
Re: 87 Caprice brake light problem
www.alldatadiy.com might have the schematics. Wiring gremlins can be a bear. I wish I could tell you where to start....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 06-08-2004, 08:20 PM
Thanks CD, actually I've made some progress. It seems to have something to do with the steering wheel tilt position. I'll checkout that site.
Old 06-09-2004, 01:22 PM
ladymech62's Avatar
ladymech62 ladymech62 is offline
Send a message via Yahoo to ladymech62
Is your tilt loose? It could be a bare wire in the wires of the turnsignal switch - it could also be in the switch itself - have someone, or you, operate the lever - the lever may not be returning to center making the contacts in the switch not line up to get juice to the taillights. The also can heat up and the contacts sink into the plastic making it it not make contact that way too . . .
Cheryl . . . Mom, mechanic, and gopher
1, 8, 4, 3, 6, 5, 7, 2 What do you mean I can't use that on a FORD?
Old 06-10-2004, 03:58 PM
Thanks Lady, yeah could be anything in there. Most likely the switch. I'm gonna spray some contact cleaner in the switch and see if it helps. If not then I'll have to pull the wheel. Check out the Lumina board, I've been talking to some people there about this
