Old 06-05-2004, 09:21 AM
godfather23's Avatar
godfather23 godfather23 is offline
Painting photo etched parts! HOW TO????
Hey everybody, donīt mean to bother you, but someone had a thread in which he talked about painting photo etched parts. I think it was a Subaru plate, which was explained how to paint it. I looked all over for that threat but couldnīt find it. Maybe somebody of you knows and can point it out to me, where I can find it!
Thanks
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 06-05-2004, 10:02 AM
Macdaddy4738 Macdaddy4738 is offline
Send a message via AIM to Macdaddy4738
Re: Painting photo etched parts! HOW TO????
Thanks
http://www.briansmodelcars.com/tutor...D=36&CurPage=1
there it is
Old 06-05-2004, 11:36 AM
Thank you, I knew I can count on you!!!
Current Projects:
Old 06-05-2004, 02:19 PM
freakray freakray is offline
AF Modelrater
Ummm.....the same 'How To' is right here on AF, maybe you guys should check out the "How To and Tutorial" thread in future....
AF User Guidelines
Old 06-05-2004, 03:09 PM
yea. I just rememberd that i saw it on that one site. Its a good tutorial!!
Old 06-05-2004, 07:38 PM
bvia's Avatar
bvia bvia is offline
Guys,
remember that the above tutorial is just for badges and other small body pieces. To paint photo-etched wing endplates (and the like) you'll need to use a special primer (metal etching).
hth,
Bill
Old 06-05-2004, 07:42 PM
AF Modelrater
Bill has a valid point there.
AF User Guidelines
Old 06-06-2004, 05:24 PM
Re: Re: Painting photo etched parts! HOW TO????
Well I know that there was something on here about that paint job. Thats the reason, why I apologized in the beginning of the threat. I was looking for hours, just couldnīt find it.
Anyways any ideas to paint a badge with two colors (like ferrari badges with yellow and black). The instruction is just based on simple putting black in the back of the badge. Well, maybe somebody has an idea for that tiny problem???
Current Projects:
Old 06-06-2004, 09:23 PM
bvia's Avatar
If it's the Cavallino (rampant pony) you're talking about, do the following;
1. Paint the entire part in a laquer or enaml based semi-gloss black (I like Model Master's Black Chrome) and let dry
2. Paint the entire part again in Tamiya acrylic Lemon Yellow and let dry
3. Remove the Tamiya acrylic paint with a q-tip dipped (but not totally saturated!) in acrylic thinner, Windex or IPA (IsoPropyl Alcohol). Go slowly and you will end up removing the yellow from the horse only.
If you go too far, simply reapply the yellow and repeat step 3.
hth,
Bill
Old 06-07-2004, 09:08 AM
hth,
Bill
Great tip on this issue. Thanks a lot!!!!
Current Projects:
Old 06-07-2004, 09:14 AM
Vric's Avatar
Vric Vric is offline
humm Tamiya TS series don't react with Tamiya Acrylic Thinner sorry...
also good luck to cover the black with Lemon Yellow
Old 06-07-2004, 03:34 PM
Pretty smart, Vric, but if you use simple acrylic paint on it, it might work. The one with the brushes!!!! So the idea was quite good, just a little thinking is neccessary...
Current Projects:
Old 06-07-2004, 07:16 PM
bvia's Avatar
Humm...the incompatibility of the ENAMEL/LACQUER basecoat with the ACRYLIC thinner is what you are counting on(i.e. it will strip the top layer of ACRYLIC yellow, but leave the semi-gloss black on the raised portions).
Tamiya TS numbers indicate that the paint is a SYNTHETIC LACQUER spray can. So if you wanted to go that route you could simply paint the base with TS29 and then continue with the above tip...i.e. using X8 as the over coat and then using Tamiya ACRYLIC thinner (or IPA or Windex or Ammonia) to remove the X8 covering the horse and the outer lip, yet not strip the TS29 making the horse and outer lip semi-gloss black.
As for the coverage, I find that when X8 is brushed on, it covers quite well...but of course you could always go with a three coat system. TS29, X2 and then X8.
Anyways, the above has always worked for me...
Since there is no "one way" to do anything, what have you used in the past to get the desired affect, VRIC?
hth and TIA,
Bill
