cracked rotor, stripped screw.
Figured out why my car doesnt want to start some times, the rotor is burnt and is cracked. Went to take the rotor off, was using the "high security" bit and the fucking screw is so tight that it still stripped the head out. Now I'm stuck with a cracked/burnt rotor and no way to get the piece of shit off. I dont have a drill-out bit or anything and I need the car for work. Anyone know how the hell to get it out, I'v tried everything I can think of.
Re: cracked rotor, stripped screw.
If you have a dremel you can try to cut a slot across the head of the screw so you can get a flat head in there, but be carefull of the wiring around the rotor.
Saturn Stealership Technician #331 |
Drill out the screw, they aren't needed. Once you have the rotor off, just get the remainder of the screw to be flush with the rest of the metal.
Uh, sure you don't need that screw until your rotor falls off when your driving.
I could drill the screw out and rethread it and put a larger one in it. Anyone know if its extreamely sensative to balance? I know most arnt, but I'v never did this to one of these motors.
You can drill out the existing screw & put in a bigger one. Last time I had rotor issues I just ended up putting a bigger screw in (because my threads were so worn that the original screw would fall out over time). Haven't had a problem since.
If it falls out again I'm drillin' a hole on the opposite side of the rotor & putting a nut & bolt on that bitch
thanks, I'll just drill it out and put a larger one in.
well you could always just buy a new distributor. ha
88 civic dx |
I think I'll put a bigger screw in it... thats free.
Can you use just any screw? I heard that it should be replaced by one from the dealer.
1994 Acura Integra GS-R Performance Mods: AEM Intake DC Sports Headers GReddy Cat Back Exhaust Ground Control Coilovers Exterior Mods: WW Body Kit PIAA Low Beam Bulbs '98 Style Integra Taillights |
Re: Re: cracked rotor, stripped screw.
And as already stated, you can drill out the old one, tap in new threads and use your own screw. GL |
Re: Re: Re: cracked rotor, stripped screw.
1990 Black Geo Storm - RIP - 1990 Blu metallic Std Hatch 1999 Milano Red Ex Coupe Current -- Ex to Si. It's Overdone, but who gives a crap. I don't! |
