Old 06-05-2004, 03:10 AM
desertmike1 desertmike1 is offline
Popping sound resolved
I have a 1999 two wheel drive ext cab 5.3 W/82,000 m
For the past several months I have been experiencing a creeking rear suspension, most notably while turning up into my driveway. The noise was soon accompanied by a randum popping sound while driving in all kinds of differant conditions.
The temporary Fix:
Each rear axle spring assembly, at their most forward and aft positions where two leafs become one leaf, there is a steel clamp that prevents the springs from splaying out, at this point there is the slightest amount of spring travel taking place, and a shot of WD40 made them as quit as a church mouse.
Unfortunately the fix only holds for about a week. So my next move is a can of motorcycle chain lube as soon as I can pick some up.
Any-body else with this kind-of problem?
-Mike
Old 06-06-2004, 11:05 AM
Galaxi-99 Galaxi-99 is offline
Ladder bar slapper!!! or a adda leaf helper It mounts at the top and uses the axle c-clamp bolt pattern . It then connects to the front of the spring hanger. This will keep your leaf springs from moving around and give you a better ride and handling down the road.
Check this out!!
Your truck was made to haul stuff around and yet still get you to work , the springs have a free pay (grey area) that makes it sloppy untill you get some weight on the box, so buy getting a ladder bar or a helper spring set up your putting pressure on the rear suspention as if you have a 500 lb load in it,,the helper spring (j.c whitney.com/springs/trucks will help you get a better ride.
