93 runs like crap
daughter bought this 2.2 liter 93 cav with 126,000 miles on it,drove a few hundred miles and we replaced ignition module run ok for 2 weeks and stated missing out at higher rpm steadily lower rpm's it would idle great this condition steadly worse until it would jerk bad finally just died didnt seem to get any gas replaced fuel filter and the car started with it still cutting out bad it went 5 miles and died daughter said it ran fine until she filled the tank with gas and thats when the hole thing started any suggestions as to what things to look for or several things thanks a bunch !!!!!!!!!
if you hang your head threw life,you will surely miss out on your true potential |
Condensation water in gas??? Try some STP. Could be plugged fuel injectors anyway. Also check plug wires, plugs, throttle position sensor, IAC valve, and throttle body. Does it restart well when it cools down? If so really clean that IAC valve and its seat. Good Luck.
