Go Back   Automotive Forums Car Chat > Volkswagen > Older Vehicles > Corrado
Old 06-04-2004, 04:19 PM
skdvr skdvr is offline
#1 Plug
My timing belt broke and I am in the process of putting on a new one, and I need ot know how to line it up...
Thanks for any help...
Phil
1990 VW Corrado
1.8L supercharged
Old 06-04-2004, 04:32 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: #1 Plug
im sure you would get a better responce at vwvortex.com
2002 Acura TL Type S
1991 Honda Crx Si
Old 06-04-2004, 04:38 PM
Re: Re: #1 Plug
I will give it a shot, I have been on their site but I did not know they had a forum section... Thanks
Phil
Old 06-08-2004, 03:28 PM
riceaterSLC riceaterSLC is offline
Send a message via ICQ to riceaterSLC
there are timing marks on the cam pulley where the timing belt goes and on the flywheel. line up the mark on the pulley with the little arrow on the valve cover.
there is a rubber/plastic plug on the bell housing that you need to remove to see the timing mark on the flywheel. line up the mark on the flywheel with dash on the block.
if you broke your belt, there is a good chance you bent valves. you have to be very careful when you go to line up to TDC, as to no bend valves, if you havent already, by turning over the motor. also, only rotate clockwise from the pass. side prospective.
92 SLC - 2933cc's of fury
84 Diesel Jetta Coupe - 42bhp of brute force
http://forums.dubr.com
Old 06-08-2004, 04:15 PM
Re: #1 Plug
Thanks for the help....
