Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 06-04-2004, 04:43 PM
Complex One Complex One is offline
Question 1973 Type-1 Steering Column Wiring Diagrahm
Hi ALL...,
I'm in the process of rebuilding a 1973 Type-1 Beetle and need any information and or assistance as to the correct steering column wire color coding for both the turn signal/headlight switch and the wiper switch which are both mounted on the steering column.
Any assistance that anyone can provide me would be most appreciated and Thank You in advance.
Jim
Old 06-06-2004, 05:01 PM
boschmann boschmann is offline
Re: 1973 Type-1 Steering Column Wiring Diagrahm
There's alot of wires in there. I suggest you get a manual. If you don't want to pay the money for a Bentley (which is worth every penny) then even a cheaper Haynes or Clymer would even have this info.
Old 06-07-2004, 08:33 AM
Thanks Boschmann,
I got everything figured out this weekend. Did continuity tests on all steering column wires, ie. ignition, turn-signals, wipers, and labeled everything accordingly. It all now checks out OK!
Thanks you for your response.
JIM
