Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-04-2004, 04:38 PM   #1
Aaron1100us
1997 Cutlass P0306 Code
My girlfriend has a 97 cutlass with the 3.1. My scanner came up with a P0306 code. I replaced the coil pack and that did nothing. I've sprayed carb cleaner around the intake, tb and can't find any vacuum leaks (so far). I've check the plug, looks good and getting good spark. Engine mises at idle and you can feel it when accelerating. Replaced the MAP a year ago when I put head gaskets on it. It's been running like this for the past 6 months or so. Had a bad wire on the ignition module that was fixed last summer. Haven't checked injectors yet. Any ideas? Thanks
Aaron1100us is offline   Reply With Quote
Old 06-04-2004, 11:38 PM   #2
Bill V
Re: 1997 Cutlass P0306 Code
Tap #6 injector with a blunt tool.
Bill V is offline   Reply With Quote
