Old 06-04-2004, 12:53 PM
blueturtle blueturtle is offline
Send a message via AIM to blueturtle
i hate screws......
well the guy i bought my car from screwed down the screws on the dizzy cap too much and to make a long story short i stripped 1 of em how the hell am i suppost to get that bastard off??
Old 06-04-2004, 01:08 PM
96Civ's Avatar
96Civ 96Civ is offline
Thats weird, my cap came with a special kind of screw that was harder to strip. Looked like a + except it extends over the edge so you can use a flathead for both sides.
Are you planning to change the cap anyways? you might have to saw off the head of the screw (which gets the cap off) and get some plyers to twist off the rest of the screw.
But that is only a last resort IMO and I'm sure someone has an even better idea.
Old 06-04-2004, 01:44 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
it should also have a 1/4 or 5/16 head on it so you can get it off with a socket. might be metric too
Old 06-04-2004, 02:22 PM
its kinda tiny im gonna try needle nose plyers and if that doesn't work im gonna get some small vise grips because its the one right by the windshield (its even harder for me b/c i have a big triangle sway bar)
Old 06-04-2004, 05:33 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: i hate screws......
it should be either 1/4in or 7mm i think, perhaps even smaller, but there should be a hex head on it, i would do that before resorting to pliers and such, those are more of a headache than a ratchet with the correct socket, not less of one. and worse case senario, pull the plug wires off, take off the distributor clamp bolt, pull out the distributor and get better access to those screws that way.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-05-2004, 11:11 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
i thought this thread was about something else...
Old 06-05-2004, 02:05 PM
89IROC&RS's Avatar
lol
Old 06-05-2004, 02:13 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Worse comes to worse and it won't come off ,Sear's sell's a screw and bolt out for stripped screws you just put the bit in the drill and slowly drill in reverse until it backs out , I have used on my center pin bolt in my diffential , Valve cover gaskets and the Targa top of my Corvette and all 3 times it did the trick
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 06-05-2004, 03:00 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
would a magnet work???if its so stripped that it just turns...it should just slide out? just an idea
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 06-05-2004, 03:07 PM
FormulaLT1's Avatar
Fight the powwa!!!
I'm pretty sure he just means the head is stripped not the threads but I have been wrong before
Old 06-05-2004, 03:10 PM
korndogg's Avatar
oh..oooops
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 06-05-2004, 06:00 PM
yeah its the head i turned the screwdriver 2 times and it was gone
Old 06-05-2004, 08:03 PM
4onFloor's Avatar
you could try to cut a slot in the screw head with a dremel or something so you can use a flat head screwdriver
Old 06-05-2004, 11:15 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
so its a philips bit?? if you so take a torkes bit (not sure on spelling there) beat it in there and and turn it with a socket and push down while you turn that should get it out hasnt failed me yet
Old 06-05-2004, 11:24 PM
4onFloor's Avatar
Re: Re: i hate screws......
a 5lb sledge should get it in there......
sorry ridge, couldn't resist
