Old 06-04-2004, 10:14 AM
Fireforge79 Fireforge79 is offline
Running Rich Need help.
Does any one know wat the common causes are for a direct port to multi port swap motor to be running extreamly rich? the A/F gauge stays peged on the rich side. Any and all information will be helpful.
Old 06-04-2004, 11:00 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Running Rich Need help.
do you have a Cold Air intake? Did you reset your ECU? It's a good idea to do that whenever changing your car. Pull the hazard fuse out for a minute. It's located under your hood on the passenger side over the strut tower in the black box (the first red one... 10a)...
Old 06-04-2004, 12:38 PM
SiZ's Avatar
SiZ SiZ is offline
Sometimes I wonder if people read someones thread and then like a week later want to just post the same thing.
Do a search, this exact topic was JUST discussed.
Old 06-04-2004, 02:17 PM
The ECU is not throwing codes anymore, ecu has been reset, and SiZ I know this was discused last week but the question was not answered, i know because i was the one the started the last thread. The injector code that was being thrown has been fixed since. that is why we can not figure out why it's still running rich. We had one theory but no one ever answered the question earlier, and that was is there a diference in injectoers through out the years, and the models over the years?
Old 06-04-2004, 04:20 PM
SiZ's Avatar
SiZ SiZ is offline
What AF guage are you using? Are you using a wideband O2, or just the stock single wire?
Hondas run rich, they all do. Rich is safe.
Old 06-05-2004, 12:17 AM
i know rich is safe but should it be runing so rich that it's smoking and you can smell gas in the exhaust. as far as the A/F gauge goes im not sure what he is using, ill ave to email him and find you. but thanks for the info.
Old 06-05-2004, 12:37 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
throw the AF gauge in the grass, then mow the yard, then put it back in. Does it still read the same? Never trust a guage, expecially ones as fickle as AF guages. Run some injector cleaner though it and see if it still does it.
