Old 06-04-2004, 09:16 AM
hazie's Avatar
hazie hazie is offline
Unhappy 2002 mustang popping front end
ok I hope someone can give me an idea of what it could possibly be, I have replaced the struts, springs, tie rods and wheel hub, so what else could it be ? It is lowered with steeda springs, mach 1 tokiko struts. but it still pops when I turn and stop on the drivers side. and only when moving we can't get it to do it in the drive way..I need help!
Old 06-04-2004, 12:28 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Well first off, we definitely need some more info here. When did it start doing it? I'm wondering if it's due to you lowering the car. Did you get the offset rack bushings for the lowering springs?
What exactly do you mean by popping?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 06-04-2004, 03:26 PM
badaZZ-five-o's Avatar
badaZZ-five-o badaZZ-five-o is offline
Send a message via AIM to badaZZ-five-o Send a message via MSN to badaZZ-five-o
Re: 2002 mustang popping front end
Ill be willing to bet it happened when he lowered the car.
Current project- 1988 mustang lx to 5.0
302 H.O
GT-40 heads w/Ford Racing roller rockers
Aftermarket intake
Holley dominator carb.
*hopefully Nos big shot
2 1/2 dual flowmaster 40 series delta
more to come.......
Old 06-04-2004, 05:53 PM
hazie's Avatar
don't need offset rack bushings have bump steer kit. I lubed allllll the bushings and connections EVERYWHERE on the front end and so far so good. Thanx anyways
Old 06-05-2004, 01:37 AM
Norkex's Avatar
Norkex Norkex is offline
Try jacking up the front end of the car, so both front wheels are off the ground, support it with jackstands, open the hood, turn the motor on, and try turning the wheel to see if you can reproduce the sound...
My passenger side had been popping after my wreck (did you buy used?) and I discovered where it was coming from when I tried to get air out of my power steering system... It was coming from my passenger side strut/tower, I know because I can see it move... Might be worth a try, just to see if you can reproduce it that way...
So, to sum it up...
1. Jack front wheels off ground
2. Turn on car
3. Turn steering from max to max...
That's how I accidently discovered where my popping was coming from.. I couldn't do it when the wheels were on the ground... I don't know how to fix it, I've been too lazy to figure it out, if anyone has any ideas, some advice would be appreciated..
Old 06-05-2004, 08:09 PM
hazie's Avatar
we tried that. it only does it when you brake or turn. so we went back and forth in th drive way. BUT we did lube all the bushings and it's still there. BUT it's not as loud which makes us believe we found it but needs more lube..and it was bought new, but I wrecked it after 2months of my boyfriend having it but thats when we lowered it also soooo? (after the wreck)not sure if it's the wreck or the lowering? it has all new frontend...did ya know cement doesn't give?
Old 06-10-2004, 10:08 PM
price111 price111 is offline
I had this annoying problem in my '92 5.0. I undid the rack bolts, cleaned everything, lubed the bushings and tightened everything up tight. No more popping sound. That cured it for me, anyway.
LOL
