Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-04-2004, 07:01 AM
cas4067 cas4067 is offline
Post need help turboing d16 engine
I wanted some info on how a d16 engine would handela a t3 turbo I am in the proccess of now installing it on my car and just wanted to know a couple of things. Like how many psi's will I be able to push and how hard will it be on the motor. The car has 81,000 miles on it the motor seems to be in purty good shape it might be leaking or possebly burning oil it's allways low and sometimes it iddles kind of low.. also I have a apc fuel/ratio gauge and I can't figure out how to hook it up i know it goes to the oxygen sensor from the manifold. but the oxygen sensor has 4 wires 1 green, 1 white and 2 black, while the gauge only has 3 wires one green, one white and one black what goes to what????????
Old 06-04-2004, 12:12 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: need help turboing d16 engine
dont boost more then 6psi on stock fuel managment i would even do 5psi to be safe,
i believe white and black are power lines..
1
Shift_BOOST
97 s14
Old 06-04-2004, 12:16 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
before you go and turbo your engine, take it to a mechanic and have a full tuneup and service done. Get all leaks and shit fixed cause when you turbo, any problem you allready had will just get intensified.
As for amount of boost, it depends on yoru setup. With a set of dsm injectors and some fuel management you can run 8-10 psi on the d16...wait....what d16 is it, btw?
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 06-04-2004, 02:42 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
why not just get a greddy kit, its really cheap.
and you shouldnt be boosting even 1 psi on stock management
i agree with punk, get those problems fix, any problem you got now will only get worse.
but i had a friend with his sohc vtec boost about 9 psi intercooled and he would race it alot and it held up. but again motors do vary
oh and throw that af gauge away, it doesnt work on stock o2 sensors
Team Lonely Drivers
