Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 06-04-2004, 02:56 AM
ShortyDTP's Avatar
ShortyDTP ShortyDTP is offline
Send a message via AIM to ShortyDTP Send a message via MSN to ShortyDTP
FMU and fuel pump OR Bigger injectors and Hondata?
Real Quick wich one this is going to be for a D16Z6 in a ex rebuilded 15,000 miles ago
the setup: A TE04h turbo from a Chrysler Le Baron (2.0 or 2.2) can't recall ,stock wastegate set at 5.5 psi , starion intercoler , mx6 BOV , oil lines water lines std manifold adapter plates ect ect ... and as you can see is a low butget thing , so now I am in the fuel mangnament problem what would you people would remomend me???
Bigger injectors and Hondata OR
anything else you guys think is better.
Thank you!
HOLESHOT PERFORMANCE
91 Laser Rs 471 whp at 22psi pump scm-6152e
98 Eclipse GST 11.4 @ 121mph Stock T25/nitrous
Jose Mendoza
Old 06-04-2004, 03:11 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
seeing as how you want like to lowest cost possible i would run dsm 450's with fmu and pump. might not need the pump.
but if you want to do it safe i would go dsm 450s, with hondata
Team Lonely Drivers
Old 06-04-2004, 06:08 AM
YellowITR479 YellowITR479 is offline
Re: FMU and fuel pump OR Bigger injectors and Hondata?
I'd say the FMU & Fuel Pump cause the injectrs and hondata are gonna run you way over $1,000.00 which by the nature of your current buildup I dont think it would justified and you probably would get the power you are looking for for the dollar.
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-04-2004, 06:59 PM
ShortyDTP's Avatar
I am going towards the 450cc and and a 10.1 FMU .
The DSM 450 are from the 1g or 2g turbo eclipce?
Jose Mendoza
Old 06-04-2004, 11:44 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
As much as I hate FMU I would say YellowITR479 is right, the cost of hondata and injectors would not be justified for your setup.
