Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-04-2004, 01:09 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
transmission stuff
alright i did a search and i couldn't really find what i was lookin for.. in an earlier (much earlier) thread i asked about this stuff but i'm still kinda unclear.. do the obd 1 engines come with a cable transmission? eg/ 94-95 b18c..
if that's true, would a quaiffe lsd be rec.? i've read that they're the best, just wanna make sure.... Oh.. one more thing.. hard to install lsd? need to get it done professionally? Thx
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 06-04-2004, 01:13 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: transmission stuff
pre 92 Civics and pre 94 Integras have cable. 92+ Civics, and 94+ Integras have hydraulic.
Old 06-04-2004, 01:14 AM
DeleriousZ's Avatar
son of a bitch! where am i going to find a cable tranny with the gsr gearing.. or maybe a b16a tranny?
Old 06-04-2004, 01:15 AM
http://www.bseries.net/html/specs/btrannyspecs.php
GSR gearing is unique to the GSR.
Old 06-04-2004, 01:25 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
You could always hunt for the elusive B17A transmission. That was the '93 (?) GSR and I think that was cable.
Otherwise any first generation B16A is a cable transmission. The '92+ B16A's were the B16A SiR II motors with hydraulic transmissions.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 06-04-2004, 12:09 PM
Re: Re: transmission stuff
B17A1 had a cable tranny, and was not geared the same as the later GSRs.
Old 06-04-2004, 04:07 PM
DeleriousZ's Avatar
so what do you guys recommend? i'm lookin for something with around the same gearing as the later gsr's but in cable form..
Old 06-05-2004, 01:54 AM
Re: Re: Re: transmission stuff
Gotcha. Didn't know that. I knew it was cable but wasn't sure if the gearing with the same.
Old 06-05-2004, 02:07 AM
You could always hybrid a tranny. I don't know enough about building trannys to tell you how, but it can be done.
Old 06-05-2004, 01:34 PM
DeleriousZ's Avatar
sounds expensive.. how hard is it to convert to hydro tranny? think it'd be worth it in my case?
