My 2000 GC has a headlight issue. They come on/off at various times , regardless of conditions..ie.running, not running, setting in the garage, bright sun or dim. No problem at night. Dealer says the multi function switch is good. They replaced the battery???? Said it was the problem. Still doing the same thing, just $135.00 later. Help!!!
Re: headlights flash on/off
so are you saying that in auto they come on when the sun is out, but when it gets dark its ok, they stay on?
Yes, they even come on in the garage with the engine off. You walk into the garage and they might flash on and off.
Re: Re: headlights flash on/off
Re: Re: Re: headlights flash on/off
BCM is the Body Control Module. I suggest you take it to the dealer who worked on it and charged you for a battery
its the multifunction switch. a.k.a. the headlight switch.its a known problem
my lights flashed on and off after having the battery changed, and the key in the ignition. Im thinking you might have a bad battery cable, ground or power terminal problem with the conputer. Or maybe the car is telling you that the key is in the ignition. Also the clock must be set to the proper time because it uses it in the computation of when to turn on the lights.
It was the multi function switch. It was replaced and all is good.
I have the same problem my 2000. Is changing the multi function switch a do it yourself project or is this something for the dealer? If you don't mind me asking, what was your cost?
Sorry but I want to confirm the flashing light problem. First do you have automatic lights? Second do they flash on and off in the middle of the night while parked? Third the light switch is in the auto position?
My JGC does this so we are leaving it in the off position until we can afford to have the light controller module replaced. I'll report back if it solves the problem. |
Yes, yes, and yes.
Does anyone know of a place to get a multi function stalk other than the dealer? I have looked on ebay, but the only ones I see are for pre 99 models.
Headlights turn while Jeep is parked
Last night my 99 JGC lheadlights came on while parked in the garage also. The switch was set in auto, The headlight options were programmed for "Lights on with Wipers" , "30 sec. Headlight delay off" , "Lights flash when remote lock activated" .
I found my battery drained this morning so the lights must have been on for a long while. Is the Headlight switch the definete solution? |
