Old 06-03-2004, 08:40 PM
RSLaser RSLaser is offline
Wobble
I have a question, if the wheels and tires are balanced, what would make the car shake while driving down the road. I have wheel spacers on the front...could that be the problem?
Old 06-03-2004, 08:46 PM
slowgsowner slowgsowner is offline
could be, or you could have warped rotors, might need alignment. is it when you brake hard? check your ball joints too
Old 06-03-2004, 08:55 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Wobble
Is the car aligned?
Old 06-03-2004, 09:15 PM
Posted by slowgsowner - 06-03-2004 at 08:46 PM
No, its when im just driving down the road. And im not sure if the car is aligned, i havent had a reason to.
Old 06-03-2004, 10:03 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Wobble
when you change the tires you should always get an alignment. you could also have a bad strut causing it too.
Old 06-03-2004, 10:17 PM
how can i tell if its a strut, or rotors....or is it one of those trial and error kind of fixes?
Old 06-03-2004, 10:38 PM
Re: Wobble
when you brake is the wobble more pronounced?
Old 06-04-2004, 04:41 AM
i.e. does the brake pedal pulse under hard braking? btw, did you have this problem right after installing those spacers? but like I said, check ball joints, bushings, steering linkages .then while your under there, check to see if your rotors cracked. EVERYTHING. but don't go replacing everything. (just check) if you don't find any thing go to a alignment shop, and get one done. (you probably need it any way) see if this clears it up. Prosses of elimination
Old 06-04-2004, 09:10 PM
Posted by BoostedSpyder - 06-03-2004 at 10:38 PM
No, its not noticeable while im braking only sometimes when im cruising at about 55.
Posted by slowgsowner - 06-04-2004 at 04:41 AM
And no again, the brake pedal doesnt pulse under hard braking. And it had the problem when i first bought the car so i dont think the spacers are really causing it.....
Old 06-04-2004, 09:23 PM
Re: Wobble
do you have your car lowered? and if you do do you have a camber kit?
