Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-03-2004, 07:25 PM
YellowITR479 YellowITR479 is offline
*Injectors* High-Low Imp...Wet-Saturated...HELP
In the process of ordering some new injectors for my car.. got a problem though...I know im running rc440's but thats all i know. Im looking to get RC650's but i dont know which kind to order. Im getting a pretty good deal on them so I figured I might as well go for the 650's cause im going to get my headwork done in a couple of months and getting 550's I think would be a waste of money AGAIN. Anybody know if I need wet or saturated and high or low impedence. Running a Hondata S200 if that helps any
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-04-2004, 01:53 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
you can run whatever one you want, but remember with low impedance you gotta run a resistor box, with high you dont need to. your choice
Team Lonely Drivers
Old 06-04-2004, 06:16 PM
Re: *Injectors* High-Low Imp...Wet-Saturated...HELP
well i kinda figured I could run anyone I wanted...otherwise why would they sell them for my car...Lemme ask the question in a better way....what kind SHOULD I get.....I figure after I get my head done and a new turbo I will be know on 450 HP's door and I dont want to get the wrong ones
Old 06-04-2004, 07:07 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Re: Re: *Injectors* High-Low Imp...Wet-Saturated...HELP
for 450hp, I would go for some precision 880cc, not too big and you still have room for more.
I am looking for 500+whp and am using 1000cc.
Old 06-04-2004, 07:27 PM
lol....still looking for an answer on the wet-saturated and high or low imp.
880!....the guy that sold me my hondata told me not to run no bigger than 650cc...why is that?
Old 06-04-2004, 09:53 PM
I don't want to answer you first question cause I am not 100% sure on it.
The guy that sold you the hondata must be a jackass. There are lots of people running much bigger than 880cc on hondata.
Old 06-05-2004, 01:04 AM
guy that told me that is an authorized hondata dist and owns 2 mobile dyno's.....tune's these things all day
Old 06-05-2004, 03:17 AM
it depends on yoru fuel line size and on how much hp your making, say if you running stock fuel lines as you get higher hp you need more fuel, so say your running stock fuel lines at 550whp, you would need to run bigger injectors then say if you were running 10an fuel lines, then your injectors would be smaller
Team Lonely Drivers
Old 06-05-2004, 12:02 PM
so basically if i ran an -8 to the AEM fuel rail which i believe is either a -8 or -10 i would be able to get away with 650's if i ran them at a highe duty cycle....lets say 70%. That leaves some extra room before the injector is "maxed" out
