Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 06-03-2004, 06:46 PM
nose-gobblin's Avatar
nose-gobblin nose-gobblin is offline
Send a message via AIM to nose-gobblin
Transmission noise
I have a 2001 forcus SE witha 5 speed tranny, when i shift gears doenst matter wut gear, when the car is below or at 2200 rps when i give it some gas to accelorate it sounds like a grinding alghouhg i dont think it is. maybe a vibrating throw berring? PLEASE HELP{ sounds makes me sick, sounds like im breaking my car
PLEASE IF YOU HAVE HAD THIS problems fixed or wutever PLEASE HELP ME!~
Old 06-04-2004, 07:38 AM
03Focus_Guy's Avatar
03Focus_Guy 03Focus_Guy is offline
Send a message via AIM to 03Focus_Guy
Re: Transmission noise
i dont have that problem with my focus (thank god) but it sounds to me like the gears in your tranny arent placed right. Has this happened ever since you bought the car? if you hear that grinding noise..ur probably grinding your gears away...so you are breaking your car
Old 06-05-2004, 07:02 AM
hmm
Yea sincei bought the car but it only does it when you accerlorate at about 2k rpms wierd, i am still under a warrete i bought so i will be taking it back the the dealership on monday, other then that the car is perfect, this isnt my fault becuase the car had 43k on it wheni bought it previous owner might have learned to shift on it!?
Old 06-05-2004, 08:25 PM
jcrt jcrt is offline
Hi... I was trying to find out on the same issue. I just bought a Focus 2000, and I've started to note and get very annoyed with what I'd say may be the same transmission noise problem you've got. It seems as if there was something loose someplace... I'm definitely not a mechanic, so I have no idea what it may be. I'm taking the car to have some pending recall issue done (something un-related), but I'll try to find out with the mechanics if they know about this also. unfortunately, I'm over the 50k warranty ... But this is quite annoying, I hope it's not a major issue... I just bought this car!
Old 06-14-2004, 09:23 AM
screwedbyford screwedbyford is offline
only 1st & 2nd gears working!!????
I have a 2000 Focus that has had SO many problems since I bought it new in Sept of 1999 that I have almost lost track... but I think this has taken the cake!
Yesterday I went to leave in it, and it would NOT go into REVERSE.. so we rolled it out of the driveway, and I discovered that it WOULD go into FIRST, and SECOND... so I had a very fun drive this morning before work driving my car to the dealership in SECOND GEAR... luckily I was able to take back streets, and the dealership isn't TOO far from my house. I had a couple down-hill stretches where I coasted in NEUTRAL for a little bit
I bought the extended warranty, and I have just over 48,000 miles on my car. The dealership said that if it is the clutch, then that is a maintenance item, but that they would call me later when they find out for sure what is going on. The clutch seemed to be working FINE to me, and I have been driving a manual transmission for 14 years.
Should be quite interesting to see what BOB ALLEN FORD says about this one... we bought both cars from them.. and I did not want to take my car here, because last time my car was in this shop, someone stole all my cd's and a radar detector out of it! They didn't want to reimburse me for the items at first, but eventually they made good.
I will post later when I find out the outcome!
Old 06-14-2004, 09:32 AM
Thanx Man
Tahk you man, i dont think that the clutch is gone on my car but sometimes it doesnt go into gear so well so imthinking that the gears arent placed correctly, Mine goes into the dealership today at about n00n and it is underwarentee so after i find out the outcome i will also post back. :\
Old 06-14-2004, 10:33 AM
re:1st & 2nd gears working
I called a transmission shop that I have used before on previous cars when I have had to have a clutch replaced, and he said that this does NOT sound like a clutch.. that it sounds more like a transmission, linkage, or cable problem...
lovely.... hoping its covered...
Rebecca
Old 06-14-2004, 12:59 PM
well I went by the dealership on my lunch break, and it looks like the ol ESP program is going to come into good use after all this time... looks like they are replacing my transmission!? They were waiting on a call back from ESP with a decision on whether or not they were to replace it with a NEW or REBUILT transmission. The service adviser told me something about one of the gears.. but I don't recall the specifics.. and don't want to post misinformation.. so when he calls later.. I will get the specifics, and post an update...
I think I am selling this car.. I am fed up.. whats next?? Is my engine going to blow!?
I can deal with a lot.. my 1991 Honda was STRUCK BY LIGHTNING while I was DRIVING.. and I brought that car back from the dead.. but this Focus has about done me in!
Rebecca
Old 06-16-2004, 08:18 AM
doesn't go into gear?
Thinking back on my car.. I had that problem too.. and I now know what is wrong with my transmission... the INPUT SHAFT is bad. I guess they need to replace my transmission as it will not go into anything but 1st and 2nd. I used to have trouble getting it into either REVERSE or FIRST after removing the emergency brake, I would have to let my car roll a little and then it would usually go into gear.. and the dealership said for the part that is bad.. that made sense...
Good luck..
Rebecca--
Old 06-17-2004, 10:33 PM
they said it was a vibrating heat shield, this F***ing suck, still does it BAD a** sound makes me SICK, but they did fix the suspension i am gettign PISSED already, WTF only had teh dumb ass thing 3 weex, !
Old 06-19-2004, 01:24 AM
ghstsnpr ghstsnpr is offline
Yes mine does that too, but it is just the heat shield around the exaust pipe. There are two metal plates, on on top and one on bottom of the pipe. You can do one of three things. 1) Tie it up with thin metal wire or cable, or 2) stick a claw hammer in between the shields and pry them open a little bit or 3) Take it to a shop and have a new exaust system intalled. I chose option 2 for now and it is fine now. My old honda did the same thing, but way worse than this.
Old 06-19-2004, 09:12 AM
they fixed the "heat shield" but it still does it, hpefulkly they the lemon laws come into play here soon so i can just give the car back and get another
Old 06-23-2004, 08:30 AM
my car got a new transmission.. the "input shaft" was bad.. I got my car back, and now the "factory rebuilt" tranny makes a whining noise.. so I took it back and asked for some cheese with my whine!
AARRGGHH.. I would like to let them keep the damn thing.. when I went to pick it up it wouldn't start.. they forgot to attach the GROUND WIRE to the engine! DUH.. ya think that is important!?? I almost lost it! Is this "heat shield" a maint. item??
R-
Old 06-23-2004, 04:18 PM
dunno
Old 06-23-2004, 04:19 PM
they called mew back and said "couldnt fix your car" so we sent it to antoerh dealer ship :0
