Old 06-03-2004, 02:02 PM
SJ-91LX SJ-91LX is offline
My ZC bogs after it warms up.
So I checked some stuff and found my lower radiator hose was still cold and the top hose was hot as hell. So I guess I'm getting no flow right?
I want to flush my radiator and put in a new thermostat and I was wondering if someone can tell me the correct way to do this.
Also where is the bleeder valve located? Post a pic if ya can.
Thanks.
Old 06-03-2004, 02:23 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: My ZC bogs after it warms up.
bleeder valve is right above upper rad hose connected to head... look here...
http://www.binghamtonlife.com/manual/2gsm/cooling.htm
Old 06-03-2004, 02:50 PM
OK I found it but nothing came out at all unless I squuezed on the tubes. Guess when they put the motor in the didn't fill the radiator correctly.
Thanks for the reply.
Old 06-03-2004, 02:58 PM
i can't remember exactly but i think you're supposed to run the engine, let it bubble out, and as soon as it starts to bubble, cut the engine off and tighten bleed valve... i tried it recently when i had same situation recently, but damn thing is so tight, I couldn't budge it... turns out... both hoses get hot, just wasn't running long enough and fan stays on all the time so bottom hose gets hot late
Old 06-03-2004, 03:23 PM
Yeah, I let it run a while before I did it.
Old 06-03-2004, 03:54 PM
you should probably test your thermostat or just put the necessary amount of coolant/water in it first... then after running it for awhile if it still gets hot like that, check thermostat by putting it in hot water if it opens it works if not...
Old 06-04-2004, 12:32 AM
Tonight after I got home from work and the motor was nice and hot I turned the bleeder screw and water slowly came out then it started to come out really good. Then about that time my car dropped to 500 rpms, just like it does when it starts to bog and no more water was coming out the bleeder screw. :|
