Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 06-03-2004, 08:50 AM
wfo440's Avatar
wfo440 wfo440 is offline
99 Dakota tranny slips from2nd to 3rd
Every time i drive it when it the truck first shifts from second to third, it will slip before it goes into third. When warmed up it will shift fine but when it is cold it will slip every time. It is a 5.2 ext. cab 4x4. Any ideas to fix this problem would be great.
Old 10-02-2004, 01:57 PM
WVMountaineer WVMountaineer is offline
Re: 99 Dakota tranny slips from2nd to 3rd
Have you found out anything out about this problem? I have a 94 that does the same thing.
Thanks
Old 10-03-2004, 12:58 AM
trannyman52 trannyman52 is offline
have the throttle valve linkage adjusted ,,,,line boost pressure too low
causing mushy 2/3 shift,,,,may want to tighten int band a little,,,
Old 10-03-2004, 08:10 AM
wfo440's Avatar
trannyman how do you do those adjustments?
