Old 06-03-2004, 12:38 AM
dssmax's Avatar
dssmax dssmax is offline
SI Heads, Fact or Fiction
A friend of friend said that to make a 1.5L a 1.6L all I would need is to swap the heads..
I checked and all the head gaskets are the same size for the 1.5 and 1.6...
Unless the 1.6 has a longer stroke to make it a 1.6 the piston sleeve should be bigger right??
I came from VW's and older chevys where we would use bigger pistons to get bigger displacement.
FACT OR FICTION can you just swap the heads to get a bigger displacement with these motors?
MAX...
Old 06-03-2004, 12:39 AM
pm7's Avatar
pm7 pm7 is offline
no...lol
89 civic lx 4dr 5 speed, 91 integra gs alloys, bone stock
Old 06-03-2004, 01:02 AM
dssmax's Avatar
Re: SI Heads, Fact or Fiction
Originally Posted by pm7
no...lol
O.K. so is it the stroke thats longer with the 1.6L?
MAX
Old 06-03-2004, 01:35 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
No the piston is bigger.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 06-03-2004, 01:25 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
ya, the piston is bigger, plus the 1.6 head has a more aggressive cam, pluss you are also goin to need to do the mpfi swap to get the full potential out of your 1.6
KoRnSaQ
Old 06-03-2004, 02:40 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
if u put an Si head on a D15B2 block would u have any gains at all? or would u only get gains if u had the MPFI on the Si head?
Old 06-03-2004, 03:29 PM
d16a6crx's Avatar
d16a6crx d16a6crx is offline
yes you would have gains just from the head, but it would be mostly because of the cam, which you can use in the b2 head anyway
1991 CRX Si
Looking for 88-91 Sedan or Hatch
Old 06-03-2004, 09:57 PM
dssmax's Avatar
Thanks for setting that straight guys.. I understand now, even though the head gasket kit is the same for 1.5 and 1.6 it does not cover all the way up to the outer circle of the piston sleve..
MAX
Old 06-04-2004, 08:32 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: Re: SI Heads, Fact or Fiction
Ok please inform us on how the piston is bigger since both the D16 and D15 motors share the 75mm bore??
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 06-04-2004, 08:37 PM
91CRXHF 91CRXHF is offline
Send a message via AIM to 91CRXHF
ya i would like to know as well
Old 06-05-2004, 12:21 AM
krustindumm's Avatar
krustindumm krustindumm is offline
true, wtf were you guys thinking? all D-series are 75mm bore.
91 Civic Dx Hatch
Midwest Honda's MySpace group
Old 06-05-2004, 11:42 AM
Hybrid1990crx's Avatar
Man, you asswipes are making me dumber by giving out bad info. Someone straighten this out please! Where is SiZ or Ami when we need them?!?
Old 06-07-2004, 11:49 AM
dssmax's Avatar
O.K. now I'm lost (again),
You are saying the bore is 75 mm on all D-series motors so there must be a longer stroke to makeup for the size displacement....
Can't be the heads or there would be a drop in compression if they where bigger...
Hrmm... DSSMAX <---- Lost again....
Old 06-07-2004, 11:55 AM
i give up on this, i thought the piston was bigger, but if they share the same bore, then they have to be the same size, so is there any difference in the pistons at all???
KoRnSaQ
Old 06-07-2004, 06:23 PM
Is the crank different from the d15 and d16a6?
