Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 06-02-2004, 09:54 PM
skit0321 skit0321 is offline
replace engine or gaskets
My crankcase gasket or whatever goes bad on these engines where they leak oil is bad, i believe the head gasket is bad also. I was wondering if i would be better off replacing these or just purchaseing a slightly used engine for the car? Also i am missing some piece that goes on the bottom in the front it is sone kind of air deflector, and seems to be why i am running a little on the hot side. I was wondering if anyone knew what it was exactly?
Old 06-05-2004, 08:33 PM
Spinman's Avatar
Spinman Spinman is offline
Just purchased a new air deflector for my '96
SKU # 25677742 Deflector
Old 06-06-2004, 10:16 AM
where did you purchase this from?
Old 06-07-2004, 12:15 AM
madcatter madcatter is offline
If you can get your hands on a whole engine, by all means do it. These are fire and forget motors. Replacement is easier and cheaper than repair.
Old 06-07-2004, 03:16 AM
any idea on where to find new engine at?
Old 06-07-2004, 07:18 AM
zimaad zimaad is offline
first look is always a boneyard.
Old 06-07-2004, 07:31 AM
RobertHammen RobertHammen is offline
Re: replace engine or gaskets
I occasionally see Aurora 4.0 NorthStar engines on eBay... have seen them run $400-$3000.
Also check http://www.car-part.com to check junkyards in your area.
Might also want to call a Caddy dealer and ask them if they know of any engine rebuilders in the area that they've worked with/would recommend.
--Robert
Old 06-07-2004, 07:58 PM
dsatt12 dsatt12 is offline
Didn't that valuable norhtstar info page mention most rebuilders don't touch these engines since they can't replace the cylinder liners and other things?
If anyone hasn't read it yet, just search- it's defintely worth a read.
Old 06-07-2004, 10:31 PM
http://www.babcox.com/editorial/us/us100232.htm
"In researching this engine, we discovered that few rebuilders are overhauling Northstar V8s - not because these engines are lasting forever (they're not) but because the Northstar V8s are such expensive and complex engines. Cadillac has no reman program for Northstar V8s (if one fails, replace it with a new one). None of the major production engine rebuilders are doing Northstar V8s, and some rebuilders told us certain critical internal parts are unavailable (such as oversize crankshaft bearings). Add to this the fact that the cylinder liners can't be replaced or overbored and it doesn't leave much to rebuild."
Old 06-07-2004, 10:57 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
well if your going to replace the engine try doing the 4.6 swap.
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 06-08-2004, 06:54 AM
Is this a swap that can be done and still work with our ECM/PCM, etc?
Old 06-08-2004, 07:22 AM
i believe it can be done, as soon as i get the chance i'll let everyone know. and Im giong to have 300 hp.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 06-08-2004, 07:57 AM
Nice...and I bet there are a few more upgrades you can do to the 4.7..but I'm just guessing. I'm almost tempted to keep an eye out in bone yards to see if one comes in and I can grab it for the future.
Old 06-08-2004, 10:51 AM
RoraStar96's Avatar
RoraStar96 RoraStar96 is offline
Send a message via AIM to RoraStar96 Send a message via MSN to RoraStar96 Send a message via Yahoo to RoraStar96
Will it fit??
the STS engine bay looks bigger then ours
1997 Aurora
"Aurora Snow"
250++HP 4.0L Modified Aurora V8 w/Autobahn Performance
On Deck: RSM intake, RSM 80mm TB
Administrator, www.oldsmobileforums.com
Administrator,Aurora Club of North America
Administrator, www.bonnevilleclub.com
Adminstrator, www.ontariobonnevilleclub.com Coming Soon
Old 06-09-2004, 12:40 AM
any chance on swapping out to an old 305 small block or somethin and bypass all the computer bullshit
