Old 06-02-2004, 08:51 PM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
Amp chosing advice???
I know you guys are probably tired of being asked this, but ok...
I want to get a good SQ amp that pushes 300W RMS and has a range knob from 20-400Hz... not 20-200Hz like some... it will be powering one twelve, what do you guys suggest???
Old 06-02-2004, 10:22 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Amp chosing advice???
Umm... what is the impedence... you wont be going past 200 on any sub. I am almost certain of that. I would suggest a nine.2 off the top of my head or a mcintosh if you have that kinda money.
www.cloudcity.deviantart.com
Old 06-02-2004, 10:56 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
wtf for?
Your sub shouldn't be playing above 100hz anyway
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 06-02-2004, 11:38 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
so the 20-200hz is the lpf right? what would be a good place to put it at? 50hz? 80hz? i jus wuna know, i realize that the higher u put it, the more bass it has
Old 06-03-2004, 03:00 AM
Ok, well, sr20... I told you about my old system, well, I had a Jensen 300W and it blew out, so I've borrowed a Sony Xplod. The Jensen was set @ 400Hz while the Sony only goes up to 200Hz, and Believe me it sounded way better w/ the Jensen, don't get me wrong, the Sony hits harder (it's about 400W) but sounds even crappier. Since Jensen and Xplod are both utter crap, the only variable in this equation that made the first amp sound better was the higher setting... did I expalin it right
Old 06-03-2004, 08:26 AM
Haibane's Avatar
dude, get a midbass driver. you will easily blow out your subwoofer trying to run it too high. The sub is not meant to handle that frequency. You need to set it at 120 at the highest and 80 is the norm.
Old 06-03-2004, 01:42 PM
but then Y did it sound BETTER w/ the Jensen @400 than w/ the Sony now at 200??
Old 06-03-2004, 04:20 PM
Haibane's Avatar
If you get a dedicated midbass, which is apparently what you were trying to use your jensen for, it will sound better, but your jensen probably died because of its missuse.
Old 06-03-2004, 04:36 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
wow, setting the crossover freq higher will blow the sub .... I guess you learn something everyday
as for why one amp seems to hit harder than another, there could be at least a dozen different reasons.
Old 06-03-2004, 08:12 PM
well unless u are happy with your sub playing all your midbass, then get good components, and set the sub's lpf to under 100hz, i duno many people that listen to their subs over 200hz, i mean any higher then its midbass, and your speakers should cover that, your subwoofer is made for LOW FREQUENCIES, if u have it turn that high, u might as well throw away your speakers and use your subwoofer for everything in your car, give it atleast 15khz yea?
Old 06-03-2004, 09:35 PM
Haibane's Avatar
Since they generally distort at the higher frequencies and draw the amp into clipping easier by spreading out the power more, wouldn't that help in blowing the speaker?
Old 06-04-2004, 12:53 AM
Ok, so can someone give me some ideas on an amp fitting my criteria, it will be powering one kicker 12 and most likely a JL W3 in the future
Old 06-04-2004, 07:50 AM
Haibane's Avatar
two subs, not going to happen up to 400hz, the amp I recommended earlier will power one sub
Old 06-04-2004, 08:05 AM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
i think he means he might upgrade to the w3 sometime in the future
Old 06-04-2004, 09:27 AM
Haibane's Avatar
www.edesignaudio.com if you hurry you can pick up a nine.2 at a good low cost
