Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-02-2004, 07:20 PM
SR20dett60 SR20dett60 is offline
quad throttle
how much does quad throttle add to hp? how can u tell how powerful they are is it by how big or something?
Old 06-03-2004, 12:10 AM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: quad throttle
what is a quad throttle?
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 06-03-2004, 04:38 AM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
The short answer is, they won't add anything unless your current throttle body is a point of restriction for your motors aspiration. Even if your current throttle body were a restriction, a quad throttle set up is overkill, it would probably be just fine to get a single larger bore throttle body. There aren't many people that actually need a quad throttle set up.
Beer tastes better upside down.
Old 06-03-2004, 04:46 AM
xyfalconsrock's Avatar
xyfalconsrock xyfalconsrock is offline
Send a message via MSN to xyfalconsrock
Re: quad throttle
Even a Twin thottle body is heaps!
Old 06-03-2004, 05:24 AM
Agreed.
Old 06-04-2004, 12:56 AM
Re: quad throttle
yeah other mods would improve wateva car ur driving.(exaust,induction,ci,computers)
Old 06-04-2004, 05:53 PM
SaabJohan SaabJohan is offline
Re: quad throttle
That depends on what you means by four throttles?
The placement and size of the throttles can affect the performance more that one might think. The throttles should also not be too small nor too large.
Also, several thottles have been used instead of a single larger one, as a large single one can make the car difficult to drive. Today many throttles are controlled by the ECU so that doesn't matter that much.
Most high power engines are using a single throttle per cylinder placed on each runner.
Old 06-04-2004, 08:07 PM
Good point, the driveability issue is worth bringing up. For instance, the throttle bore on 1st gen. MTX Dodge Neons was tapered in the middle in order to improve driveability. So the bore was actually a smaller diameter in the middle. But to make a generalization, a quad throttle set up is not necessary on the vast majority of road cars.
