Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 06-02-2004, 07:08 PM
big dave's Avatar
big dave big dave is offline
options on 2002 Aztek
Just bought the aforementioned Aztek. The dealer said the rke's were lost so I bought one from GM and took it to the local Pontiac dealer to program. They hooked up the scanner and couldn't get it into program mode. They ran the vin and say that this particular Aztek didn't come with RKE, but for $400 he could get me a new BCM and then I would have RKE. If this is true, couldn't I just find a wrecked Aztek that had RKE and get the BCM from it?
Thanks,
David
Old 06-02-2004, 07:24 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: options on 2002 Aztek
What is your vin number. I can run your vin and see what it says.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 06-02-2004, 07:43 PM
big dave's Avatar
VIN# 3g7da03e02s581838.
I appreciate your help.
Old 06-02-2004, 08:27 PM
Flatrater's Avatar
Main GM Guy
I see you have a service contract on your car. Which is good if you have a problem. Ok now the way I see it Keyless entry isn't an option on your car but it is a standard feature. Just because it's not listed on your option label doesn't mean you don't have it. Either the shop did it wrong or the feature is turned off in your BCM. All that would need to be done is to go inside the BCM and see if the feature is turned on or off. Turning it on and programming it should fix your problem. The best advice I can give you is to try another dealer.
Here is your option break down.
Merchandising Model : 2BK46 -2002 AZTEK 4-DR
Gross Vehicle Weight Rating : 2287 kg (5043 lb) Order Number : DZWDZ7
Build Date : 03/27/2002 Build Plant : 32SB
OPTION CODES
AJ7 - RESTRAINT SYS SEAT INFLATABLE AR9 - SEAT FRT BKT, DELUXE
A15 - DEEP TINT WINDOW, RR DRS CAP - VOM CAP CODE PROCESSING
CH8 - FLT-NCR CORPORATION C6X - GVW RATING 5037 LBS.
C60 - AIR CONDITIONING, CUSTOM DG7 - DUAL POWER SPORT MIRRORS
FE1 - SUSPENSION SYSTEM, SOFT FE9 - FEDERAL LOW EMISSION VEHICLE
FLT - FLT-FLEET ORDERS FR9 - AXLE RATIO 3.29
GQ1 - AXLE RATIO STD IPB - TRIM INTERIOR DESIGN
JM4 - BRAKES, POWER ANTILOCK K34 - CRUISE CONTROL, RESUME SPEED
K68 - GENERATOR 105 AMP LA1 - 3.4 LITER 3400 SFI V6 ENGINE
MX0 - TRANSMISSION, 4-SPEED AUTOMATIC M15 - TRANSMISSION, AUTOMATIC 4-SPEED
NF7 - FEDERAL LOW EMISSION N36 - STEERING WHEEL,4-SPOKE SPORT
PY0 - WHEEL, 16" ALUMINUM QRD - P215/70R16 TIRES
SAL - RAMOS ARIZPE, MEXICO PLANT CODE UH8 - CLUSTER-COOL TEMP,TRIP ODOM, TACH
U1P - RADIO, AM/FM STEREO W/CD, PROGRAMMABLE EQ AND RDS, REAR CARGO CONTROLS AND 10 SPEAKER SYSTEM U76 - WINDSHIELD RADIO ANTENNA
U96 - 6 SPEAKER SYSTEM VQ1 - FLT-SPEC ALLOWANCE-NO ADV
V2G - CREDIT IN LIEU OF FUEL V73 - VEHICLE CERTIFICATION U.S.
YB6 - BASE AXLE YD5 - BASE FRONT SPRING
YD6 - BASE REAR SPRING 1SA - 1SA PACKAGE
1SZ - VALUE GROUP SAVINGS 14B - DARK GRAY
14I - DARK GRAY 16U - ARCTIC WHITE
6AT - COMPONENT FRT LH COMPUT SEL SUS 7AT - COMPONENT FRT RH COMPUT SEL SUS
8NH - COMPONENT RR LH COMPUT SEL SUS 9NH - COMPONENT RR RH COMPUT SEL SUS
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 06-02-2004, 09:33 PM
big dave's Avatar
Thanks for the info.
God Bless you and all Republicans
