Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-02-2004, 06:23 PM
smity88capri smity88capri is offline
88' caprice deisaling
when i go to turn off the car it still wants to run help please.
And it is carburated, 305 automatic.
Old 06-09-2004, 04:36 PM
ladymech62's Avatar
ladymech62 ladymech62 is offline
Send a message via Yahoo to ladymech62
Re: 88' caprice deisaling
It is idling too fast! Check to see if the butterfly on the carb is fully open and the fast idle cam (passenger side of carb) is dropped down. You can lube it so it can drop. You may have the idle set too fast (driver side of carb) - possibly to keep the car running with the AC on? Is there an idle solenoid on the carb? Is it working? Adjust it properly with the AC on so when you turn off the car it will drop the idle down to the idle screw on the carb. If it doesn't work, back it off so it can work off the one on the carb. Then adjust the idle so it will keep running while the car is in gear.
Cheryl . . . Mom, mechanic, and gopher
1, 8, 4, 3, 6, 5, 7, 2 What do you mean I can't use that on a FORD?
Old 06-10-2004, 02:34 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
idle speed and/or timign is too far advanced, also youre carb may have carbon gunk buildup at the throttle plate blades, get carb cleaner and clean base of carb real good and hten also tighten up all the carb assembly screws and slap choke shut and then right back open againon her a coupe times when you hold throttle open a good amount, tighten carb miunting bolts too, stuff works loose over time,
check this stuff often,
also grab a vacuum guage real quick and make sure idle vacuum is between 18 and 22,
adjust timig to correct it,
now go burn rubber off the tires
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
