Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-02-2004, 05:56 PM
Daas_Smeagol's Avatar
Daas_Smeagol Daas_Smeagol is offline
Exclamation Help sudden problem with 4th gen
car is 93 Si 4ws , was driving home from work and got caught at a red light..waited when the light turned green, the car was hard to throw into first, and the clutchpedal stuck at the floorboard, the poped back out a few secs later, any help would be appreciated...(feels like clutch does not release)...now it is almost impossible to get it to go into any gear.
Old 06-02-2004, 10:56 PM
DJ Brady DJ Brady is offline
Send a message via AIM to DJ Brady Send a message via Yahoo to DJ Brady
Re: Help sudden problem with 4th gen
could be a couple of things... if your clutch eventually popped back out on it's own, it's not a broken cable.
If it's very sticky, it could be a bent/broken clutch fork, bent/broken fingers, heavily damaged throwout bearing or a heavily frayed cable causing it to stick... w/out knowing more details about the symptoms, I'm going to go with, "You need a clutch job".
Old 06-03-2004, 12:19 AM
any suggestions on which clutch is best? (not a high hp set up)
centerforce,exedy,unorthadox?
Old 06-03-2004, 01:06 PM
partyhardryan16 partyhardryan16 is offline
is it a cable clutch or hydrolic clutch? my dads car had a problem similar to that and it was leaking hydrolic fluid from the clutch
Old 06-03-2004, 08:03 PM
Hydraulic...honda mech. said it is probably just the master or slave cylinder...
Old 06-03-2004, 08:39 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
exedy
