Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 06-02-2004, 04:56 PM
ralvarez ralvarez is offline
Problem with rear camber correction...
Hi, I have a set of 4 tires 215/40x16 mounted on 16x7.5 wheels, and recently put a set of lowering spring (neuspeed sport spring) on my '99 Civic. The car went down about 1.5 inch on the rear but the camber on my rear wheels went negative also. The problem is that if I correct the camber the rear tires will start to rub with the fender. What can I do? The offset of my wheels is between 38mm and 42mm. I'll appreciate any help.
Old 06-02-2004, 06:59 PM
BullShifter's Avatar
Re: Problem with rear camber correction...
205 45 16
How much is the camber off? If it's 1.0degree or less don't worry about it.
Old 06-02-2004, 09:58 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
If it's more than 1.5-2 degrees off, then you're only alternative if you want to fix it, is rolling your fenders.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 06-03-2004, 09:19 AM
Thanks guys... I guess I will change the wheels instead of bending my fenders.
Have any of you hear of a rear arm link (or another piece of the rear suspension)that lets you put your wheels like 1 inch more inside the wheel bay, so your wheels doesn't rub the fender??
There's a friend of mine saying there's a piece like that. He saw it about 4 years ago from Suspension Techniques on a mechanics convention. Just wanted to know...
Old 06-04-2004, 02:45 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Rolling fenders is really simple, I would just recomend that. Just hold a bag of buckshot on the outside and slowly hammer it in with a ballpien hammer then paint it.
