Old 06-02-2004, 03:00 PM
sykotic1 sykotic1 is offline
Fan Override
Well I've seen it explained before but I'm really not sure how to do it. Apparently I just need to run a wire to the ground so both fans are on all the time, hoping it won't be a problem with a 180 thermo (had a single electric fan running all the time on that crazy mustang and it ran fine in the winter too) so if anyone can help me out with how I go about doing this (which wire it is im not sure) I would really appreciate it..
Old 06-02-2004, 03:51 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: Fan Override
sooo you want both fans to come on when your turn the ignition on and you want them to shut off when you turn your ignition off??
Old 06-02-2004, 05:29 PM
Dober89 Dober89 is offline
Re: Fan Override
Boo to this. My car was setup like this when I bought it and I dont like it at all. Before my antenna is up all the way the bastard fans are roaring. I just had my friend spend a number of hours to fix this because mine was grounded out but they messed with the ecm the way the other people did it.
Old 06-02-2004, 06:35 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: Fan Override
You could run them off a switch to turn them on and off as needed.. But you cant forget about it..lol
1991 Camaro Z28
Old 06-02-2004, 07:54 PM
96CamaroSS's Avatar
96CamaroSS 96CamaroSS is offline
Re: Fan Override
SLP sells a fan switch so you can turn your fans on and off when you want. For $69.95 and you don't have to hack your harness.
This is only for the 93-02 camaros...
http://www.slponline.com/view_produc...RTNUMBER=63011
Old 06-02-2004, 09:33 PM
Re: Fan Override
well i had thought it was only one wire that would need to be grounded and they both can turn on and off like that yeah..i dont really care about any noise coming from them as long as the bearings are still good, and im not crazy about having a switch because my car isnt a robot toy :-p guess its just preference but if i could rig maybe the secondary or the primary or both to start up on ignition and off like that id do it.
Old 06-02-2004, 11:44 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
both fans are run off one relay i'm pretty sure. there's a much easier way of doing this if you want to install a switch for them. on the driver's side firewall there's 2 relays that look the same. one is for the fuel pump i think, and the other for the fan(s). on both of them there is an orange wire coming out, you want the relay with the smaller orange wire. run this through a switch to ground. this way your already using the existing relay and all you have to buy is about 8 ft of wire and a flip switch
Old 06-02-2004, 11:58 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Fan Override
yea, that's how i did mine, spliced into the relay wire.
Old 06-03-2004, 12:57 AM
Re: Fan Override
alright ill give it a go. whatever gets the temperature down gets my vote :-D
Old 06-03-2004, 01:06 AM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
Re: Fan Override
i had to do that on my 91 rs, went through
1 alternator a month, i wouldnt do it.
all you need is a new relay and a new
temperature switch. a mechanic screwed
my car up big time by doing that. i ended
up trading it off, cause the electrical system
was shot.
Old 06-03-2004, 01:07 AM
Genopsyde's Avatar
The President
Re: Fan Override
i replaced relay, fan motor, and temp switch, the relay kept blowing, that's why i had to hot wire it.
Old 06-03-2004, 01:10 AM
Re: Fan Override
how long ago? mine lasted a year before
major problems started, it was so bad i
couldnt drive the car at night cause
i didnt have enough power to run the
lights id turn them on the volts would
drop and if i had the air or heat on
the car would die.
Old 06-03-2004, 01:18 AM
Genopsyde's Avatar
The President
Re: Fan Override
been about 3yrs now, but remember, I hardly even drive the car.
Old 06-03-2004, 01:20 AM
Genopsyde's Avatar
The President
Re: Fan Override
damn, I don't even remember exactly how i wired it, i know i have wire going to the battery from the relay, and the switch is on the inside under the headlight switch.
Old 06-03-2004, 01:21 AM
Re: Fan Override
good deal then.....mine was a 3.1 v6 ( junk )
anyway. i have to knock on wood cause i
havnt had any problems with the 90 v8 rs.
