Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-02-2004, 12:37 PM
ahmad72 ahmad72 is offline
Reverse Sensor Malfunction 95 Camry
Hi... My reverse lights don't come on when I put my car in reverse - I checked the fuses and the bulbs - everything appears ok. It may be the reverse sensor that's malfunctioning - where do I find this sensor and how do I fix it? Thanks! - ahmad
Old 06-02-2004, 07:25 PM
Joe W Joe W is offline
Re: Reverse Sensor Malfunction 95 Camry
Two things should be checked:
The sensor you refer to is probably the neutral safety switch.This is located on the transaxle where the linkage goes into it.There are tests for this procedure in a Haynes manual.
The second place to look is the wiring in the trunk at the hinge as this degrades the wires from moving when the trunk is opened.
