Old 06-02-2004, 04:22 AM
pizzaman2004 pizzaman2004 is offline
Tool to remove door panel
I have a 1993 Buick LeSabre. I have a bad door lock and want to remove the door panel on the driver side. Does anyone know what tool is used to remove it and where I might get one.
Old 06-02-2004, 08:19 AM
Jed Rule Jed Rule is offline
Getting the panel off is the easy part. You can get the tool at any parts store. Don't miss the screw behind the red courtesy lite on the end of the armrest. Wait till you try to get the lock actuator out. You have to remove the whole latching assembly. Difficult but not impossible. Read the directions carefully in order to properly index the new actuator.
Old 12-29-2005, 02:17 PM
rustbucket rustbucket is offline
Re: Tool to remove door panel
Trying to replace lock actuator on 99 lesabre.
OK, I got the latching assembly loose, but how do you get it out? It attaches to 4 metal rods that I havent figured out how to get un attached. Also, where do you get instructions for doing this job?
Daily Driver: 2008 Chevy Impala - 30000 mi
Others:1993 Chevy S10 - 85000 mi, 2000 Saturn SL2, 1987 Buick Lesabre RIP, 1999 Buick Lesabre
Old 12-30-2005, 11:41 PM
cheesep cheesep is offline
Re: Re: Tool to remove door panel
Check this link. Find your car and look under Specification Charts
http://www.autozone.com/servlet/UiBr...rGuideYMMEYear
Old 12-31-2005, 01:06 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
The connecting rods are attached to the latch with plastic clips. You simply twist these and pull them back (they stay attached to the rods) then the rod are snapped into a small groove in the latch assembly. The hardest part is not being able to see in there very well to do the job. Once you have the rods disconnected, you can disconnect the wiring a lot easier from the assembly and pull it right out.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
