Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-02-2004, 02:52 AM
dlbrown69 dlbrown69 is offline
Send a message via AIM to dlbrown69
92 Civic Code 43 !!!!!!!!!!
I have this civic that keeps setting this code, i can't figure it out at alllllll. Any help?
Old 06-02-2004, 07:18 AM
grimple1 grimple1 is offline
Send a message via MSN to grimple1 Send a message via Yahoo to grimple1
Re: 92 Civic Code 43 !!!!!!!!!!
here is the diagnostic section from Mitchell onDemand. on code 43. it's a fuel system code.
Is the engine code 43 accompained by Check Engine light and Poor driveablity? Yes? Proceed to basic fuel system diagnostic. No? Reset CEL light and Warm engine up to normal operating temp (until cooling fans come on). Hold engine at 3,000 rpms for 2 mintues (put car in either N or Park) Does the CEL code 43 reappear? No? Intermittent Failure, system is ok at this time. Check for poor connections on O2 sensor, ECU and connector located at right Shock Tower. Yes? (i'll spare you the long story at this point.. it's a voltage issue... take to a mechanic that can test voltage between pins D14+ and A26- as soon as ignition switch is turned on.)
GL. sounds like a pain in the ass.
Old 06-03-2004, 12:42 AM
itechengineers itechengineers is offline
Send a message via Skype™ to itechengineers
im going to say = the CHILTON manual says 43 is a fuel system supply code...
if you dont have a manual
http://www.honda-acura.net/forums/sh...d.php?t=125370
has a lot of info that may be able to help on a lot of issues.
