Old 06-02-2004, 12:25 AM
candp candp is offline
blowby
oil in throttle body?what causes this,what to check?thanks 96 1.0 engine
Old 06-02-2004, 01:49 AM
westsidex's Avatar
westsidex westsidex is offline
Check for a clogged PCV valve.
Get to Know Geo Metro: The Small Car with Big Ideas - http://geodriver.tripod.com.
Old 06-02-2004, 10:54 AM
Re: blowby
put in new pcv,toped it up oil.worked for awhile then started smoking again.
Old 06-02-2004, 11:19 AM
geozukigti geozukigti is offline
See if the oil is in your TB. If it's in your TB, and your intake manifold, it could be blow-by on the piston rings, or bad valve seals.
Old 06-17-2004, 04:09 AM
Re: blowby
finally did a compression check and redid squarted oil gained 25lbs each sure sign rings?
