help! need computer code!
today my 97 accord threw a P1456 from the computer. i cant find these codes anywhere. autozone said its a dealer specific code. got anything?
Re: help! need computer code!
i'll give you the simplest answer to this. Evap System leak detected.
check the following: Faulty fuel filter cap proper vacuum connections fuel tank leak EVAP control canister vent valve malfunction " " circuit malfunction EVAP purge control solenoid valve malfunction " " circuit malfunction EVAP bypass solenoid valve malfunction " " circuit malfunction Fuel tank pressure sensor malfunction " " circuit malfunction EVAP control canister malfunction GL hope that helps. |
thanks
cool, thanks. i talked to the dealer and he said it was the gas cap being loose. tighten and drive 2 - 20 mile cycles. if that doesnt fix it, how could i test for the other things you said it could be?
to test rest of problem (if they exist) you can take your car to dealer and have them to figure out the problem, or you buy service manual and do it yourself.
service manual should be this one, it's $40 on ebay
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB Electronics: Apexi VAFC (untunned) Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar. Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2 Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads |
yeah, i just wrote what the computer told me. i'd just take it to a dealer. screw dropping a gas tank. crush your dang ribs? no thanks.
Re: Re: help! need computer code!
Why would you want to remove gas tank?All components that need to be tested (if need to be) don’t located in gas tank. Gas tank has only fuel pump and fuel level sending unit, which can be tested without removing tank, they even can be replaced without removing gas tank. |
