Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-01-2004, 09:02 PM
John Olson John Olson is offline
Post 96 Maxima antenna mast replacement
Can someone explain how to remove what's left of my '96 Maxima antenna? The antenna came apart between the bottom and next higher telescoping sections, so the top portion essentially motored it's way off the car. I've removed the nut, but can't seem to get the bottom section out. The replacement mast has a spring-loaded clip that will compress as it's inserted, then expand to hold it in place. Is it safe to "pull" the old section out, or am I looking at dealer labor to finish the job? Thanx.
Old 06-02-2004, 10:50 AM
Dubbya Dubbya is offline
You could try to unbolt the motor and work it out that way.
Try this link for instructs on the whole thing.
http://www.carstereohelp.org/DoItYou...ssanPwrAnt.htm
Warner
96 GXE 175,000 miles and counting.......
