Old 06-01-2004, 07:44 PM
scdnad scdnad is offline
700r4 lock up
does any one know how to wire up the lock up torqu converter on a 1984 700r4 trans it's going in a (63) p/u so i have no wirring all i know is the trans has three wires in a plug on the drivers side of the trans i think you need to make one 12v hot through a relay also ty it into the brake so it will disingage the lockup when braking and the tv cable needs to be adjusted by moviing the carb linkage to full throtle position then you push the botton on the side of the tv cable bracket to allow it to center it self when in full throtle mode any trany guru's out there i think im in deep help i've allready wasted one trans because the tv cable adj help
Old 06-02-2004, 01:34 AM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
Re: 700r4 lock up
wow thats way to much for me to type. but here is a link that you can find all your info on. also im asuming now you know the the TV cable is different than a detent cable on line a 350 or 400. you cant use the same cable or brackets. if you look at the link they have the greatest TV cable kits, it makes it imposiblr to scre up the setup, and they also have TCC wiring kits. also on there sight it hase instructions on how to wire everything so you can read every little detail before you even order if you choose to.
TCC wiring: http://www.bowtieoverdrives.com/cata...SUBCAT&CATID=O
you will want the kit that says: "compleate GM plunger style" , if you have the plunger style brake light already. i dont know what came on that year. if not you can use the relay stye one that will fit anything.
as for the TV cable stuff i dont know if you need anything but here is the link for that stuff.
http://www.tvmadeez.com/
if you want to order anyting just click on the online catalog. i gave you think links to where the info is not to order parts. hope this help.
Old 06-02-2004, 12:25 PM
Re: 700r4 lock up
thank's 68 chevelle that's just what i was looking for great web site how about a corect block for my 69 427 435HP corvette rodster any ideas ? thank's again scd
Old 06-02-2004, 01:32 PM
Re: 700r4 lock up
no problem. and as far as the 427... LMFAO. wow thats a good one. that one your on your own for man. that would be a nice find somewhere. oh yeah... and just to clarify dont put the space between the "68" and "chevelle". now there is someone that has a space in the name. no worries though but i actuly think that guy is some stupid moron that keeps coming back. but anyways dont worry about it.
