Old 06-01-2004, 06:43 PM
Electricity's Avatar
Electricity Electricity is offline
Driveway Clutch replacement
Ya, so i got an 88 civic wagovan, 1.6l, 5 speed manual. and my clutch is compleatly fuq'd. Can someone give me info/a link as to how i'd go about replacing that bad boy in my driveway. A friend is gonna loan me an engine lift. but is that all i need to do? Yank the engine out and replace the clutch disk?
thx in advance.
Old 06-01-2004, 07:13 PM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
Re: Driveway Clutch replacement
have the helms manual with you. that's your most important tool.
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 06-02-2004, 07:24 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
don't pull the engine. just raise the car up, unbolt the tranny while its got a jack under it, then lower the tranny down, change the clutch, then reverse. basically.
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 06-02-2004, 08:18 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
When we put a new clutch/flywheel/pressure plate in my buddys '99 EX we just unbolted the tranny and dropped it. Make sure you use the clutch alighment tool...it makes everything a lot easier when its going back together.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 06-02-2004, 08:21 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
http://www.quickhonda.net/index2.htm
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 06-03-2004, 12:21 AM
itechengineers itechengineers is offline
Send a message via Skype™ to itechengineers
i gotta say there are many ways to do it. you can pull the engine, but i suggest only so if your interested in cleaning the block or swapping out other things while your at it. I've done a clutch swap boths ways and i personally would pull the motor out becase if your by yourself its easier to get the trannie to mate with the block while the entire motor in out of the car. But if you have a friend or 2 helping you out, you wont have a problem with leaving the motor in the bay and dropping the trannie alone. I droped the trannie along and had a hard time getting it to mate by myself. askled a friend to go under and bench it while i lift and aling and in 5 mins it was done. so if your all along, pull it alll out and clean up your bay and block while your at it, even pull out the intake manifold / stripe it and clean all that black $hit outt of it. ...
to make things easier on you, crack the wheel knockle hub bolts while the car is on the floor (should be the first thing you do) unless if you have an impact gun.
Old 06-03-2004, 12:27 AM
hey take a look at this site.... you can use a lot off of it for referencces::
http://www.honda-acura.net/forums/sh...d.php?t=125370
look at the 92-95 helms manual, you can reference from it, dropping a clutch is pratically the same on most hondas, just ceartain things may be different.
