Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 06-01-2004, 04:03 PM
chris lewis chris lewis is offline
Question Starter keeps burning up
Engine starts, and starter burns up within 10 seconds. HELP!!!!!
Old 06-01-2004, 08:16 PM
albert cornejo albert cornejo is offline
Re: Starter keeps burning up
i burned two starters because the wires werent tight enough
Old 06-16-2004, 09:12 PM
xxJosiahxx xxJosiahxx is offline
hmmmm
you probably bypassed the selenoid on your starter. if you do this then the starter will not disengage the flywheel/driveplate and it will stay on while you drive your car and it will turn at insain rpms...eventually it will blow out. you need to connect both of the wires to the large stud farthest to the outside of the starter... otherwise you are, in fact, bypassing the selenoid.
-Josiah
