Old 06-01-2004, 03:54 PM
wesw02 wesw02 is offline
Send a message via AIM to wesw02
power steering ..............?
some body plz help me, i was driving down the road and i took a sharp turn and my power steering went out and now it won't work and when i turn off the car the steering column doesn't lock up like it usally would it is still turnable???? i'm completely clue less
Old 06-02-2004, 01:59 PM
fluffybunny fluffybunny is offline
Send a message via AIM to fluffybunny
Re: power steering ..............?
just my opinion but i dont the the loss of power steering is cause from the same thing as the column lock. could be wrong, is your power steering pump whining or hav ebubbles in it? no leaks right? fluid?
Old 06-02-2004, 03:47 PM
yes it has fluid, not bubbles or whining in my pump and no leaks in my lines. any more ideas ??
Old 06-02-2004, 05:58 PM
pump
i believe that i have traced the probelm to the pump we took off the pump line and the was no fluid being pumped even after i started the car and tried turing the wheel. so does anyone know where i can find out how to change the poweer steering pump on a "2000 Grand Am with V6 3.4L" ????????
Old 06-02-2004, 07:23 PM
i believe its relatively easy, three bolts behind the power steering pully are the hardest to get to, but can be removed by turning the wheel...........13mm-1/2in i believe......... dont quote me on that. i do believe you have to remove the motor mount and overflow to have more room. other than that its a breeze.... just dont forget to fill your new p/s pump with fluid before you start her up. nothing too difficult to do though, good luck
Old 06-02-2004, 09:58 PM
thanx buddy
Old 06-05-2004, 01:53 AM
gordon24chic gordon24chic is offline
Send a message via Yahoo to gordon24chic
hey, got a 99 GA SE and just had my PS pump, serpentine belt and water pump replaced this week. The motor had to be lifted in order to get the pump off b/c of the pulleys... went ahead and took her to a garage and let them fool with it - some special tool required to remove the pulleys I believe.... GOOD LUCK!
Old 06-05-2004, 10:17 AM
nick0750's Avatar
nick0750 nick0750 is offline
gordon there is no reason to lift the motor to do the repairs you mentioned and no special tools are needed to perform this job,
