Old 06-01-2004, 02:34 PM
avilaZ71 avilaZ71 is offline
clunk in steering column
I have a clunk in the steering column when i stop or hit a bump.. I talked to the dealer when it was still under warrenty, they said they greased the steering coulmn. It didn't happen for like 9 months and now it is back.. I can't see any place the grease it .. does anyone know??
Old 06-01-2004, 02:50 PM
smcelhe smcelhe is offline
Re: clunk in steering column
I have a 99 Silverado and the dealer replaced the steering shaft on it twice. The shaft that was replaced is between the firewall and gear box.
Old 06-01-2004, 04:29 PM
TxNitro TxNitro is offline
Check with GM, just had a recall on my '04. Seems the steering shaft assembly that holds the grease has a bad tendancy to crack and loose all lubrication, causing grinding sound and popping. One recall does it all. $70 free fix from dealership, takes about an hour for the guys to fix.
Old 06-02-2004, 07:52 AM
WGP WGP is offline
If your truck is out of warranty and you want to repair the clunk yourself you can get the intermediate shaft grease kit from the GMDieselTech.com.
Go here for complete instructions and text of the Intermediate Steering Shaft Clunk TSB (need to register with this site to view)
This is a common problem.. My 2500HD started clunking during slow speed turns at about 18Kmiles. Had the grease job and its been OK so far.
Bill
2003 2500HD LT Duramax CC SB 4WD,OilGuard BypassFilter, JK MegaFilter, LiftPump/PreFilter, Bilsteins, Retrax RollTop, J&J Millenuim Boards, Coolant Filter, Alli-deep-pan, High Idle, Mods UOA History
04 Impala, 99 Saturn SL1
